pk1023
Sep 10, 2013Explorer
Normal to always see some voltage on Elec Brake pole of 7way
Heya guys, so I am still trying to troubleshoot this brake controller issue in my 2012 Nissan Quest.
Because it's a van they had to hardwire everything in, no harness was available.
This picture shows what a 7 way tester shows at idle:
https://lh5.googleusercontent.com/-QKyyvpZFDHQ/Ui-znxF202I/AAAAAAAAA90/-MjoelG-o6k/w346-h461/13%2B-%2B1
This pic shows the same tester with the manual switch all the way depressed:
https://lh6.googleusercontent.com/-4BoX0ffYn6U/Ui-zd3oXK5I/AAAAAAAAA9Y/ky1LHAk8O9g/w346-h461/13%2B-%2B1
Soo, my question is it normal to see some voltage ALWAYS on the electric brake line?
I also noticed that whenever you step on the brakes even lightly in park that the electric brake pole goes hot for a split second and then falls back to this normal state.
I am guess it's just a bum controller. But, I am nervous to go out and buy a new one and void the warranty on the old if it's the wiring.
I just can't imagine what's allowing some voltage on that line. And I know that the spike is coming from the controller for sure.
