wcjeep
Jul 27, 2017Explorer
You won't really know how much extension is necessary until fully loaded. If you need 21" or more extension go with Torklift. Their stuff is not cheap. It is good quality hardware. I would also recommend Torklift frame mounted tie-downs, Super hitch if necessary, Fast Guns and Stableloads. Skip airbags for now. Try the stable loads before purchasing airbags. Airbags unload the suspension. Airbags support the weight on a cushion of air instead of the rear suspension. Stableload engages the truck suspension immediately.
Non Torklift extensions usually decrease tow capacity quickly. I'm using round numbers. Do consult your specific owners manual. A non Torklift extension typically decreases your tow capacity by about 1/3. Most extensions are not rated for weight distribution hitch. They decrease bumper pull by 1/3 from 5k lbs. The max your truck could tow would be about 3500lbs +/-. SuperHitch with weight distribution starts at 10k lbs a day and goes up depending on model.
I changed out the car hauler trailer tongue jack and used some wood for a great step when exiting the camper.
44,068 PostsLatest Activity: Jun 09, 2026
