Homeless_by_Cho
Aug 30, 2019Explorer
otrfun wrote:mbloof wrote:Interesting. Both connectors on the 7-pin umbilical cable we use for our '19 NL 8-11 are female and electrically and physically identical to each other. Doesn't matter which end of the cable is plugged into the male connectors on the camper or truck---works fine either way.devildog1971 wrote:Well yes and no.
They are both male connectors,
Take a close look at the 7-pin jack on the NL camper and a close look at the 7-pin jack on your truck.
Mine look different.
Both ends of my truck-2-Northernlight umbilical cord look different as well.
I ended up LABELING mine as once I plugged it in BACKWARDS and it did not work. There is clearly a TRUCK end and a CAMPER end of the cable.
At least on mine there is.
- Mark0.
X2 Same on mine.
LeRoy
44,056 PostsLatest Activity: Jun 25, 2013
