otrfun wrote:
devildog1971 wrote:
Does anyone know where to purchase a sewer hose that will fit in the factory mounted compartment. That I think was provided to hold a sewer hose. If this orifice was not intended to store a sewer hose can you please tell me what the intended use was. Thank you
Siletzspey wrote:
. . . Whether a shaved 4-prong or as-is 2-prong, the female end will only fit near the opening of the bumper tube, so you can only mount one fully-fitted tube in the bumper . . .
We have a 2019 NL 8-11. We were able to to fit four 10 ft. Revolution hoses (brown hose/yellow ends; sold at Walmart) inside the bumper on our 8-11. These hoses have 4-prongs. If you carefully shave each side, between the prongs, just shy of the black gasket, it will fit inside the bumper. Did this about 7 months ago. Have used the hoses numerous times since then with no issues.
Northern-Lite increased the size of the rear bumper after enough of us complained about it. You may have one of the larger ones on your unit.
