ldsmith48's avatar
ldsmith48
Northstar 850 sc Electric roof lift
Looking for someone that has the 850SC with the electric roof lift. I have injured both shoulders, and most likely will no longer be able to manually lift the roof. Called North Star was advised there was no way to retro fit the lift in my camper. From studying Videos on you tube of the lift system. I really think it could be done. The videos do not show enough details. Would like someone that has this system to send some photos of the systems attachment points. Cannot find any newer NS campers in my area that I could view this system.
  • I had 2 Northstars and an Outfitter with Heco lift systems in them , all were problems if the roof weight was much more than just a shell of the basic roof , adding cabinets , AC ... and the crank handle brass gear would strip - or push out while raising the roof .
    I built handles with more extension that made it easier to lift . I know a drill would just chew up the crank gear , the gear is made soft so it fails first . I see now they have changed to making the cranks with harder gear material and the weld to the handle is supposed to break if to much force is applied to it
    I used to push up on the roof with my shoulder to push the roof up the first few inches which helped ; now I have had surgery's on both and that would`nt work for me either
    More torsion can be put in the system ,but after a while that weakens too .
    About the time I sold the Outfitter they where making a elecric system to add to the Heco one , but the motor would go behind the rack and mess with the bed space
    But I see now that Rieco -Titan is making a system to replace the whole Heco one . I would defiantly check it out if I had a pop up now
    https://www.riecotitan.com/image/catalog/instructions/electric-roof-lift-instructions.pdf
  • I’m not sure if this could help, but can you use a drill to raise it?
  • Sorry for your injury. No local RV repair shops were interested in this modification? Very surprised.
