jimh406
Nov 30, 2018Explorer III
I doubt the bouncing is from the Stableloads. Airbags will disengage the overloads which is the opposite of what you want.
A few questions, what air pressure are you running? I suggest 80 rear and probably 70-75 front. In spite of people saying their rigs handle great, it’s going to feel different than what you are used to. Are you sure the fastguns if you have them are adjusted right?
BTW, I wouldn’t remove a propane tank. It’s not going to be fun to be out of propane on the mtn. I doubt the propane tank is going to change the handle significantly. But, it will stink to not be able to have the fridge, stove, heat.
FWIW, don’t remove extra batteries either if you have two.
44,070 PostsLatest Activity: Jul 01, 2022
