Bedlam
Nov 30, 2018Moderator
Sliding-into-home wrote:
Are you sure the fastguns if you have them are adjusted right?
Only thing I know about adjusting fastguns is what the tech at the dealer told me during delivery. Tight enough to just barely require 2 hands to close, and always on the hook that's farthest away. Closing the front ones, I can visually see the cabover drop about a an eighth of an inch as it cinches down on the bed mat. That sound right?
Adjust the FastGun turnbuckle so when you look through pin/lock hole tension starts once half of the hole is obscured, the remaining closing action should be under tension.
44,070 PostsLatest Activity: Jul 01, 2022
