Sliding-into-ho
Nov 30, 2018Explorer
Bedlam wrote:
Adjust the FastGun turnbuckle so when you look through pin/lock hole tension starts once half of the hole is obscured, the remaining closing action should be under tension.
Oh that's right, the tech dude actually did mention that! I'll make sure they're adjusted.
With respect to the stable loads, they are definitely in contact with the spring, even before I have loaded the camper with gear/water. The lower overload gap is essentially gone as well.
With respect to Ranchos, even in the 9000XL range, I saw multiple flavors on whatever web site I was on the other night. Couldn't tell the difference, but a few of them listed different ride heights.
44,070 PostsLatest Activity: Aug 07, 2026
