texasclarks
Aug 04, 2014Explorer
Note to self: when hooking up the stinky slinky extension to the drain that is 20 ft away it is best to hook up both ends...one to the end coming off the trailer, the other to the elbow that goes into the drain. If one of these is not connected and you go to dump your black tank the waste DOES NOT make it to the drain without a lot of work and rubber gloves.
And FYI, the stink beside your TT doesn't dissipate while you are at the CH.
