- FishermanExplorerIf you go the 2 nut method, a plop of thread locker will probably keep them together. Just make sure you line the 2 nuts up to allow a deep socket to cover both when cranking.
- valhalla360Navigator
JRscooby wrote:
If you have enough thread there, screw on 2 nuts, then jam them together. Work same as welding, but if you need to take it apart you can
You need to use a deep well socket if you go this route. Otherwise, it may just grab the first nut and break it free.
But unlikely you will ever need to take it apart, so a quick tack weld should work fine. - JRscoobyExplorer IIIf you have enough thread there, screw on 2 nuts, then jam them together. Work same as welding, but if you need to take it apart you can
- amxpressExplorerWhile you’re under there you might consider lubricating the threads.
- Another vote for Fisherman's solution. Perfect.
So much easier with a socket and cordless drill. - bgumExplorerFisherman has best solution. While your there some lubrication would help.
- FishermanExplorerJust have someone weld a couple of nuts on the end, then you can use a drill driver with the right socket to go up or down.
44,056 PostsLatest Activity: May 04, 2014
