Really not much of a difference between them when written into any specification and/or manual
Goes to both warranty and liability
If it is 'recommended' and you don't follow that recommenation and something happens...why would they be obligated to provide warranty?
Ditto 'required'...same thing as above, but more forceful in verbiage...
PS...since most vehicles today are computer controlled everything...it can change timing on the fly to protect itself
Plus, towing heavy is way different than driving around town shopping without towing heavy.
The margin for octane requirement is very different in those two applications/usage.
Has to do with duty cycle...
womps wrote:
Lynnmor wrote:
I guess Ford gave up on trying to explain to users how a turbocharged engine produces high cylinder pressures and should have premium fuel to prevent knocking. Since folks will disregard any kind of advice and use whatever is cheap, all they can do is write a generic owners manual and provide safeguards to prevent engine damage from low octane fuel. If one cannot even understand this phrase: "premium fuel with an octane
rating of 91 or higher is recommended" why even print a manual?
Because there is a difference between “recommended” and “required”.
