Terryallan
Oct 12, 2017Explorer II
Dick_B wrote:
Usually when a truck passes the front of the tow vehicle will turn toward the truck (all by itself) and the driver has to correct to the right to avoid a collision.
This also depends on which way the wind is blowing...
That is not sway. But normal actions caused by the bow wave of the truck. If it is bad enough to scare you. Then you need to work on your WDH setup.
