jwandvassie
Apr 29, 2018Explorer
Based on your tests, you have a very high resistance connection somewhere between the trailer plug and the light. The meter has a very high Resistance so you can read the 12V but when connected to the light, all of the voltage is being dropped across the bad connection.
You should check and/or redo the connection at the plug and at the light. If the bad connection is in between, you may have to run another wire.
Good luck and please report back your findings.
44,056 PostsLatest Activity: Nov 19, 2013
