NVR2L82AV8
Dec 26, 2022Explorer
AF811 wrote:
Hello,
That is quite the technical post on your OEM SSL stereo. I agree wholeheartedly it is a POS, but mine did function well until a few weeks ago when the CD could not be retrieved from the unit. After viewing your post, I know that I will never be able to install a new unit especially with the speaker fader system. Also the unit you installed is no longer available. It seems that a 3.0 is what has taken the 2.0 place? In your opinion, do you think the 3.0 would fit my Arctic Fox 2013 811? The pictures you posted are absolutely identical to my 811, i.e, thermostat, water heater switches, control panel and Cummins generator switch. Your opinion would be appreciated.
Doug in Mesa Az
Doug,
I'd pull the trigger on the 3.0. If it wont fit just make sure you can return it. My guess is it will fit. I imagine the 3.0 has some enhancements my 2.0 does not have. Let us know how your swap out goes.
