Just need to get the extension put in from the hitch to the end of the supertruss.
The double hitch is a custom fab job but very heavy and I'm confident it will be fine for my needs as I'm only pulling just over 4000lbs with it. The truss is 36" long and very secure. I'll know how it does this weekend as I'll pull the mill to a job on my maiden milling job with the new camper.
On the extension length: for me, it's important to get as much clearance as I can for the mill as I often pull it into places where you might not normally go with a camper ;) and I need to be able to make some pretty tight turns, sometimes darn near jack knifing the mill to get it in there. SO I need to make sure it will NOT hit the back of the camper! The old one sat up much higher and on a 2" foam insulation sheet to boot, so I had tons of clearance but the AF990 drops down to within 1" of the mill's hydraulic box so just some uneven ground will cause an issue.
