wmoses wrote:
I install a Fumoto quick oil change valve on all my vehicles and that makes changing my engine oil very easy, and also reduces the chances of the oil drain plug threads in the oil pan getting stripped. lf you had one of these installed and are prepared to bring along a drain pan and filter wrench then changing your own oil when travelling would be very easy.
I have a Fumoto installed it makes changing the 15 quarts of oil a lot easier. I considered changing it on the road but would have to deal with the used oil.
