jerem0621
Nov 02, 2014Explorer II
Oil extractor
I'm considering buying a vacuum oil extractor for my oil changes. Does anyone have any experience with these devices? Pros, cons?
Thanks,
Jeremiah
Thanks,
Jeremiah
fj12ryder wrote:6.7 tow rig wrote:Yessir! I have those on all my vehicles except my motorcycles. Sure makes changing the oil a snap, and also collecting samples for Blackstone Labs.
This is much better and just as clean.
jfkmk wrote:
I'm not sure how much you'd gain by doing an oil change like this. You have to crawl under the vehicle to replace the filter anyway. In my experience the filter is a messier job than draining the oil.
eHoefler wrote:John & Angela wrote:
If you own a smart car, or at least a diesel, it's the only way to change the oil. Quick, easy and clean. The oil only gets changed once every 10K anyway but it makes for quick changes. There is no drain plug.
If that in deed is the case, it is designed to have the oil removed that way.
