Searching the Internet for law suits like that will come up with nothing...large
OEM's will buy your silence with money and a contract that says they are not
admitting to anything and that if you disclose anything...you have to give back
all the money plus get sued for every penny you have
Journal bearing clearances are designed for 'that' engine. Meaning the torque
listed in the specification, the RPM range the computer is told to limit to,
the ambient temp range specified, and for this discussion...the oil characteristics
The ambient temp range vs viscosity is spelled out in the manual.
Going to a tuner has the potential to exceed the journal bearing's oil flow (GPH/PSI)
to allow metal to metal contact
Won't instantly blow up the engine, but it will wear out sooner
Ditto the rest of the stuff oiled via the galleries
