profdant139's avatar
profdant139
Explorer II
Sep 04, 2018
OK to carry gas can on tongue near battery, well secured?
I carry a small gas can for my generator, usually in the covered cargo bed of my truck. But it is in the way. I want to put it on the tongue of the trailer. I can easily build a secure place for it to sit -- that is no problem, and it is not going to move around.
My concern is the battery, which is mounted on the tongue in a plastic box. The idea of anything electrical right near a gas can is troubling. Yes, the gas can is the modern type that supposedly does not give off fumes. And yes, the battery is in a box and does not give off any sparks, that I can see.
But I am one of these ultra-cautious people, so that is why I am asking. Would this setup create any risk of fire or explosion? Or am I worried about nothing?
Thanks in advance for your input.
  • As long as it's not mounted above the battery where a leak would fall directly on the battery box...no worries.
    You realize every gas powered car has a battery and electrical components in the engine bay.
  • There is no perfectly safe place to carry an extra gas can in all conditions.
    Mounted securely on the tongue is as good as any place. Better than attached to the rear IMO.
  • Should not be a issue, that's where the propane is located as well. Would just make sure it is secure in a good quality container.
  • Jerry, good point about removing the gas can while connecting and disconnecting the battery -- I have seen minor sparks at those times. Better safe than barbecued.
  • A certified Fire Marshal may object, but if a high quality gas can (all fuel containers are not equal), and properly secured, I'd not worry about it. If battery has good solid cable connections, no reason for spark. I would remove gas can before any battery servicing, or connecting/disconnecting. Otherwise, I'd not worry about it.
    OTOH, I will not replace your RV, in the event it is destroyed. :)
    Jerry
  • Yes, I think it's safe. I have done the same in the past.
