- Old-BiscuitExplorer IIIDid you follow the instructions posted on that label?
It's a manual pilot.....has to be lit with a lighter. Long BBQ one works great.
It uses a White Rodgers gas valve.....so turn blue knob to 'pilot' and hold against stop. Light the pilot flame while holding blue knob until thermocouple is heated up. Then turn blue knob to ON
If pilot flame will not light off then could be bad thermocouple.
IF pilot flame will light but not stay lit when knob released could be bad thermocouple or the ECO (high limit probe that comes out the back of gas valve) has tripped/failed. They are only good for one time operation and are not replaceable......have to replace gas valve.
Clean up thermocouple with a light sanding and make sure connection at gas valve is tight.
Otherwise replace it. A Jade pilot assembly (pilot with orifice and thermocouple)
That doesn't fix...then gas valve
This is assuming you have good propane flow thru pilot orifice and main gas orifice. - CavemanCharlieExplorer III
TucsonJim wrote:
Can you provide the model number?
First of all, do you have propane? Check by turning on a burner on your stove and make sure it lights. Do you have at least 12VDC on your battery.
Turn on a few lights in your rig to make sure they are brightly lit. Even better, measure the battery voltage to make sure it's at least 12V.
If you have a water heater switch inside the rig, make sure it's turned on.
Push the blue knob in and rotate it to the pilot position. You should also hear the igniter sparking.
If all is well, it should light right up. Hold the blue knob in for another 30 seconds or so, and then rotate it to the full on position.
Nope, don't need 12 volts for that one. And, no auto start either. Make sure you have propane.
Light the stove to get air out of the lines.
Then go to the water heater. Turn the control to the pilot position. I ;think; on that one you hold the blue knob in to start the pilot. (If not, then there is another knob somewhere you must depress.)
While holding down the right knob use a grill lighter to light the pilot. The pilot will be over near where the two small lines enter that big hole in the water heater. It may take awhile to get it to fire the first time.
After (hopefully) you get the pilot light to fire you must continue to hold the knob down for oh, a minute, maybe two. Then slowly release the knob. The pilot should stay lit. Then rotate the knob to the run position and away you go.
If this doesn't work let us know and we will go from there. That's a old unit and there could be a few things you might have to fiddle with to get it to work.
Have a nice Day.
Doesn't it have these directions printed right on it??? - JBarcaNomad IITry here,
http://www.atwoodmobile.com/manuals/waterheaters/MPD%2093756%20SP%2011.19.07.pdf
Scroll down to the "Pilot Operation" Bottom right on page 3. It talks about it step by step
Hope this helps
John - TucsonJimExplorer IIEDITED - Ignore my previous post. I was thinking of an auto ignition..
