teardrop55's avatar
teardrop55
Old water heater drain
Hello all, this is my first post and I have a question about a water heater. I have 78 Fleetwood Prowler. It has been stripped down to the frame and Im building a teardrop trailer on it. My question is that the old water heater that was in it has a garden hose connection in the access panel. Its very difficult to get to since it is up behind the gas tube for the burner. There was no plug in it and it leaked water out of it when i filled it to test the water heater operation. What is this connection for? Theres no way a hose could have been hooked up to it. I bought a plastic garden hose connection plug for it so that i could fill it and test it but it still leaks. Is it supposed to be a one way valve that is now leaking? Was it supposed to be used to flush the water heater or is it just a drain for it? Hopefully one of you guys have seen a water heater this old and can tell me. From what Ive seen all the new ones have a screw in metal pipe plug or anode rod for the drain which would incredibly more simple for me. Thanks in advance.
  • I put a new washer in it. I think its leaking where it swivels on the stem part of it.
    I apologize for the pic size, just wanted to give good images so people could see what I'm talking about. I can take them down if necessary. Can you elaborate when you say you cant scroll to see other posts? I can scroll to the right and see mine and everyone else's post text. Are you using a phone? Im on my desktop. I dont know if I can make them smaller now. Ive closed the windows to the image host site and dont think I can get back to it. Would have to take them down and reupload them.
    What was the point of adding this connector in here and removing the 1/2" plug. It was a pain to try and hold the metal part from spinning while trying to screw in the plastic plug. Having the original plug would seem to have been much easier.
    One more thing, does anyone know what kind of tank is in this water heater, aluminum or steel? Just want to know if i should try to get an anode for it. And also was wondering, on the steel tanks, if they are glass lined why do they corrode and need an anode rod?
    Sorry, a lot of questions and info in one post. Tried to make paragraphs to separate it.
    Thanks everyone
  • BTW, make the images smaller, I can't even scroll to see all of the print in other posts.
  • The garden hose fitting replaced the original plug. I have a Model Temp heater with a valve, same difference. The water hose fitting can be removed, if you desire to do it. The leaking may be caused by a bad hose washer. If you want to turn it out of the heater, a basin wrench may be the best tool.
  • Great photos!
    Looks like someone over the years has screwed a water hoce adapter into the 1/2 inch pipe opening in the tank.
    You could try removing burner tube, remove plug and try a large easy out to remove the adapter.
  • It is an American water heater, model RV-6
    It doesnt look like it was added on by a previous owner and from looking at I'm not sure how to take it off. It looks like the sheet metal is behind the flange of the connection. I was hoping I could take the back cover off and slide the unit out of the case so I could get a good look at how its connected to the tank so I can replace with a plug. I had to rotate that clamp just to be able to install the plastic plug so it doesnt seem like anyone has ever had to install a plug or hose into it. Im confused.
  • It's probably an 'add on' by a previous owner and was put there to drain the water heater. I have a valve added on to mine instead of a plug. Same reason, a previous owner needed to drain the system, maybe frequently, and didn't want to fuss with a plug that was behind a gas line.
  • Do you have make and model?
    Atwood water heaters are aluminum tanks. Tey use a 1/2 inch nylon plug on the exterior. This is used for draining.
    Suburban water heaters are glass lined steel tanks. They use an anode in 3/4 (?) pipe whole. This is to prevent the tank from rusting out.
    Some older rigs had American Water Heaters. Yours should have either Atwood or Suburban.
