I have a 2000 Lance 815 that I would like install a vented range hood in. Old brochures don't list one as even being an option. Anybody know of a reason that it can't be done? Thanks
Sure it can. I just did it to my 2002 wildcat 5th wheel. be sure you buy a 12 volt range hood. You have to be 1/2 handyman. You have to cut a 3 1/2" x 10 " hole in the side of your camper. You then find a 12 volt nearby power source and your all set. If you should run into a wall stud leave it alone and just blow the air around it if it metal. If it's wood, cover it with metal. This is just in case it ever cough fire.
