Taco wrote:
My last truck was a 94 f350, it wasn't a bad truck but it made the mistake of breaking they day before I wanted to go atv riding 160 miles away so it kept me up till all hours of the night fixing it. a week or so later I got a 2012 2500hd silverado.
I pretty much keep vehicles till they break often enough or at the wrong time and make me mad. It almost got replaced a couple of years earlier when it got me stuck on wet grass with it's 2wd open rear diff.
My take on older vehicles is that they are cheaper if you work on them yourself and are willing to tolerate the higher possibility of it not working when you need it or are willing to tolerate a ride on a tow truck when you want to be going somewhere else.
People on here talk about maintenance, sure it is important sure it can help it last longer but the truth is as a vehicle ages, no amount of fluid changes make up for the fact that every sensor, the starter, alternator, fuel pump, belts, hoses, water pump, ignition, ecu, etc. are all potential failure points that only grow more likely with age. I don't know many people that go and replace all these parts before they break and the truth is that the junk that most auto parts stores sell might not be any more reliable than a 200k used oe part. so unless you want to replace every last part on it with parts from the dealer IF they are still available. you have a higher likelihood if a ride on a tow truck and a fun vacation derailed with an older truck. but it is cheaper, depends what is important to you.
Hi Taco,
You are right, but a new vehicle can break at the most inopportune time as well. Even if its on the manufacturers coin it still stinks. Just search this forum... lots of newer trucks break... leaving their owners just as frustrated..
PS... I think your truck is SWEET.. Love the new GM 2500 HD's
