Thanks everyone for your comments. I'm leaning towards the following options:
1.
VIAIR Dual 485C with 2.5 Gallon Reserve Tank for $840.00. It flows 3.82CFM at 0 PSI and 2.09CFM at 100PSI.
2.
Extreme Air Magnum Kit for $950.00. It flows 6CFM at 0 PSI and 2.6CFM at 100PSI.
3.
Extreme Flow Belt Drive for $1500 (the compressor is only $425 but the mounting kit to attach to the engine is another $1100.00). It flows 8CFM at 100 PSI.
Considering the costs, the ExtremeAir Magnum looks to be pretty close to the best balance between performance and cost. The belt drive solution looks spectacular but the mounting kit is way more expensive than I can justify for this project.
