- colliehaulerExplorer IIIOne thing with a single axle trailer you don't have tire scrubbing when turning sharp. On small TT with dual axle most of the time they had 13 inch tires where a single axle had 15 inch tires, on the ones I looked at.
- jerem0621Explorer III've had both a single axle (current) pop-up camper and a 32 ft dual axle TT. They both tow smoothly. Backing is not an issue with either one.
I heard that dual axle trailers ride smoother...can't say that they do as both of my trailers ride smooth. The maintenance is less than 1/2 the price on the single axle (less tires and they are smaller).
I've had a single axle utility trailer for years, never had a problem with bounce or sway on any of them.
IMHO...it's a non issue...buy the trailer you like and if it has two axles..so be it...if it has one..so be it.
Thanks!
Jeremiah - SunbirdExplorerI had two 19' tandem axle trailers followed by two 17' single axle trailers. My experience is that with tandem axles you have twice as many tires to blow out.
17' and smaller are usually single axle. Bigger than that single axles are very rare. The manufacturers add the second axle to carry the additional weight. How big a trailer you want is a personal decision. - tragusa3ExplorerI found less than 1k payload on my single axle to be limiting. We also had a bearing failure in the desert and realized right there how stranded you can be with a single axle. Of course, some travel with a spare hub... come to think of it, I may travel with one even on my 2 axle trailer.
- FishermanExplorerLike the majority has indicated, dual axle trailers float, single axle trailers tend to bounce more.
- SoundGuyExplorer
rbpru wrote:
I would think the only reason the manufacturer would select one or two axles is because of its intended use.
I wouldn't count on it. Take a look at the specs for the current 2015 version of my own Freedom Express 192RBS - CCC a generous 2182 lbs ... friends of ours are about to take delivery of an almost identical trailer, a Starcraft Launch 21FBS - CCC a mere 1190 lbs even though both are double axle trailers. :E
The devil is in the details. :W - rbpruExplorer III would think the only reason the manufacturer would select one or two axles is because of its intended use.
Two axles would usually indicate they expect more stuff to be hauled. The manufacturers are rarely accused of over designing a TT. - SoundGuyExplorer
samhain7 wrote:
Do you mind me Pm'ing you for more info. I'm just east of the smoke.
By all means! :B - dadmomhExplorerAgree with Soundguy....our HTT 23SS, which was box only 20'+ had 2 axels, as does the 21SS. The 19 model, which was likely box about 16 or so had one axel only. One advantage of 1 axel over 2, for sure, is 2 less tires to buy when it's time.
- profdant139Explorer IIAs a long-time single axle person, I would go with dual axles if they are available on the model you like. The cons are extra cost (so what?) and a loss of some storage space (because of the extra wheel well). The biggest pro is safety -- a blowout on a single axle can be very serious, while on a dual axle trailer it is not a big deal.
I would also think that when towing in mud or sand, a trailer with four wheels would "float" on top and would not dig in, the way a two-wheeler would.
But they don't make a dual axle in the model we wanted, so here we are with one axle. Life is a series of compromises.
44,051 PostsLatest Activity: Sep 25, 2025
