Roadlover's avatar
Roadlover
Ongoing Onan 2500 Generator Frustration
Well, the frustration with my Onan 2500 generator continues. After posting questions and several searches regarding why my Onan 2500 generator was first operating poorly then not at all, I changed LP tanks. Now, when I hit the start switch, the generator starts immediately, but as soon as I release the remote switch, it shuts off. The same happens when I push and release the switch on the generator. But as long as I hold the remote or generator switch, the generator runs well and very smoothly. Someone asked if I had a light on the generator which would have to do with error codes, but I do not. If this helps, the light on the remote switch will not turn on. Any ideas?
Thanks,
Ken
  • darsben wrote:
    Some models of Onan generators exhibit this behavior when the low oil switch activates
    SEE: http://www.flightsystems.com/pdf/onan-rv-troubleshooing-guide.pdf
    Page 5 may give you your answer
    A very common problem with many generators: faulty low-oil sensor switch
    Typical example is generator will start but runs for just a few seconds.
    Easy trouble shooting is to (check oil level first) short across the switch to bypass it.
    If genny runs okay then you know that it's the switch.
  • I had the same problem with an Onan Camp Power 2500. I found that the start/stop switch on the generator would not stay in the run position. The generator would start with the remote start switch but, unless I wedged the switch on the generator to the run position, it would quit as soon as I let go of the remote start.
  • It may be a sign of not outputting voltage. My gas 2800 Microlite has done this twice. First time it had 8 hours on it, and was under warranty. It was a failure of the rotor and / or stator ($1600+!!). Second time at 7 years it was a failed voltage regulator; part cost was about $225 from Flight Systems, and I did the diagnosis & repair.
    The little Onans get their spark voltage from the battery when cranking. Once the start button is released, they are supposed to get from the voltage they generate. Thus, if there's no voltage, there's no spark.
    If you can use a VOM, there's a troubleshooting guide online at the Flight Systems website, I think.
    They dropped the Micolite's low oil sensor some time back, I believe before 2000.
    Good luck with it.
    Jim, "Sobriety is fine, as long as you don't overdo it."
  • Some models of Onan generators exhibit this behavior when the low oil switch activates
  • i would have to say a bad switch when releasing its going back to ground and turning off instead a open position
