IB853347201 wrote:
When you remove the filter does the water pressure return to normal on the hot and roadside?
problem is not connection outside. I ran w/o filter.
Old-Biscuit wrote:
Hot water heater is FED from COLD water Line.........
Is Water Heater BYPASS OPEN?
DO you have a 'FILL' Valve?
Is it OPEN?
If you turn Pump ON....does Hot/Cold Flow water?
Ya, I find it extremely odd that the hot water is just cold water fed through it having my issue.
I've never touched any water heater valve till today. The cold water input, but this was after the problem occurred & I put it back into the original position after diagnose. I didn't see any other valve. I will try the pump tomorrow
