campigloo wrote:
I know you’ll find this hard to believe because I did too. I had a similar problem. Hot water flowed but not cold. I took the toilet supply apart and there was white plastic grains that looked like coarse sand; same stuff in the kitchen. I was told to wash the inside of the water heater. Huh? I replaced the anode rod while I was at it. I had to rinse it several times. It may not be your problem and it doesn’t make a bit of sense I know, but it worked.
That was exactly it, thanks! I did it about a week ago though just wanted to have my feedback on the matter encase anyone else has this problem.
