MR_MAC
Aug 18, 2013Explorer
We also have Jayco 28 DSBH, "like it" has no ac in bunks, not a problem so far, might work on it. One thing is top bunk has a squeaking noise, bad for the guy on the bottom, going to work on that too. Also no place for a rubbish pail, moved water pump back in cab. under sink and cutting shelf to make room for one. When looking at TT at show the Jayco to me was built better, and had a bigger counter top than others with this floor plan. One more thing is units made by Keystone have a rubber sweep on slide out, whereas Jayco does not but uses a soft gasket seal and if wet water stays on roof of slide when its in, not a big problem, dry with towel from in side. The master bed rm is tight but being 6'2" I fit and sleep straight out. I will say after having two Jayco's and one Keystone (Sprinter) went back to a Jayco. Rob
44,068 PostsLatest Activity: Jun 21, 2026
