Grit_dog
Jan 27, 2022Trailblazer
theoldwizard1 wrote:
My biggest concern, especially living in FL, would be adequate cooling. Some manufacturers offered oversized radiators in their towing package. This is something to look into.
Also. Check the rear axle ratio. You probably don't want anything lower than about 3.73.
Of course buying used means you will be doing normal maintenance: brakes, shocks, steering component. Might be a good time to add an extra leaf to the rear or go deluxe and add a springs (bags).
He’s talking about a 2500/3500 truck.
There are no cooling system “options”. And by lower, you mean deeper gears, which will absolutely help the truck he’s buying….if his intended purpose is as a hauler, as stated.
And there is a great chance it’s a 4.10 truck. That said, 3.73s will work and I wouldn’t turn down an otherwise good truck for having taller gears for his purpose.
