Turtle_n_Peeps
Jun 06, 2014Explorer
Bruce H. wrote:
If I remember correctly, the TST tpms installation literature recommends setting the high pressure alarm at 20% higher than the cold psi. That equates to 60 psi for my tires (I was expecting it to alarm when the one tire hit 60 psi but it didn't). The obvious implication is that TST considers a psi increase of greater than 20% over cold psi to be a safety issue.
If the consensus is that a higher psi range is acceptable, I will reprogram the TST system to alarm at a higher setting, say 30% over cold psi.
Bruce
As stated, don't worry about the high pressure warning. Just set your alarm for low pressure warning and go on vacation. This from a guy that takes dozens and dozens of tire temp and pressures on the weekend. :)
44,068 PostsLatest Activity: Apr 17, 2021
