BeMurda
Dec 05, 2022Explorer
towpro wrote:
I went to look up the actual specs on that truck and the owners manual says there should be a separate piece of paper in the glovebox with more information about using a slide-in camper.
Here is other things I found. (dated 2018)***Link Removed***
***Link Removed***
This second link shows you what each accessory weighs and than has charts to your carrying capacities.
just a quick view looks like this truck starts at 3752 lbs and goes down from there.
Thanks, I looked more closely, the package I am looking at with the 11,900 GVWR has a starting capacity of 3995lbs.
I am not really understanding how I will put another 1000lbs into the truck camper as others suggest. What is comprising this weight? Thank you.
