mbloof
Dec 15, 2022Explorer
BeMurda wrote:BigSwick wrote:BeMurda wrote:towpro wrote:BeMurda wrote:
I made the bed length decision quickly. Maximum payload, fuel tank and flexibility.
Order date 12/12/2022
Job 1 / Priority code 10
F-350 Lariat Crew Cab Long Box
Carbonized Grey / Black Onyx
7.3L
4.30 gears
Lariat Ultimate
Camper/Snowplow
FX4
Clearance Lights
Dual Battery / Alternator
Max Recline Seats
Good Luck. I hope you get it quickly. (hope you even get it by next camping season)
Thanks. I have an out if it doesn't arrive by June. It is the quickest job code and highest retail priority code so I'm hopeful. Also gas have been faster apparently. But the Fifth wheel prep package worries me about adding delays. I added it to get the bed 7 pin connector. Maybe I should have just had it installed after the fact. But labour is expensive here in Canada.
On my 2019 F250, the plug cost about $50 online. Plug it in under the bed, cut a small hole and install in bed. About a half hour including time to figure out where you want to put the hole.
Thanks, I had the dealer remove the fifth wheel prep package.
I hope I get it by June... eek
Oddly or silly as it might be, in 2017 the Factory 5th wheel harness plugs in near the bumper and is long enough to route under the truck to the front drivers side (one of 6) stake/support channels.
- Mark0.
