myredracer
Nov 11, 2013Explorer II
Other reasons ST tires fail??
There have been soooo many threads and posts on ST tires here about what the best one is and why they fail sometimes. I was just reading one of those "threads from heck" - ST tire thread from heck...
But I don't see much if any discussion in that thread or elsewhere on the following:
For those that live on the west coast (like us), when you buy a travel or 5th wheel trailer (unless it's a really small one), it gets towed to the dealer by a delivery driver. That means if it comes from a plant in Indiana, where most of them seem to, you have over 2,000 miles on the tires. I've read some say that ST tires should be replaced at 5,000 mile intervals so this means that your brand new travel trailer has tires that are about 1/2 used before you take it for the 1st camping trip. I think it's just plain wrong for this to happen. I think this could easily be one factor in premature wear or failure for west coast owners.
And to go further on the delivery driver thing, if a driver is paid by the mile, it seems to me they will be motivated to get to their destination sooner than later. This means they could easily be driving in excess of 65mph for extended periods. And they may also be hitting lots of potholes, bumps and cracks. None of this is good for ST tires. And if the driver is driving a long distance like to the west coast, your ST tires could have taken a lot of abuse during shipment. How would you ever know? You could have over 2,000 miles of hard abuse and you'd never know looking at the new TT on a dealer's lot. I would hazard a guess that this is one contributing factor in tire blowouts. Of course the first reaction in a blowout would be it was "those cheap Ch*nese tires".
It's my understanding that hitting a lot of bumps, cracks and potholes in the roads is bad, especially at higher speeds. The I-5 in northern Cal. has settlement between adjacent concrete slab sections. We have had 5 tires damaged there. Two on a car and 3 on a new Toyota truck. In each case, the steel cords snapped and caused lumps in the treads. The Toyota dealer replaced the OEM Michelin tires under warranty. I have to think that hitting big enough bumps, cracks and potholes often and heard enough can lead to damaged cords and bulges in ST tire treads.
I've read elsewhere that "curbing" ST tires is not good because of how the sidewalls are made. Just how bad is curbing ST tires? Is once bad or would you have to do it many times to cause damage?
Some TT frames/suspensions have a lot of flex in them. This can cause tires/wheels to go quite a bit out of camber when the trailer weight gets "thrown" side to side as in cornering and lane changing at speed. For example, the trailer in this photo is being pulled out of a tight spot in a campground and you can see how much the frame and suspension flexes causing the tires to be way off camber. You have to know that the tires will move out of camber as the trailer is moving down the freeway or being pushed to one side around a corner. I'm guessing that this happens more than TT owners may realize.
I just think that there are other reasons ST tires fail other than not being at the correct PSI or they are driven frequently over 65mph. To be sure, there are better ST tires out there like Maxxiss, Carlisle or even Marathon, and there are many at the lower end of quality. But to say just because the tires are made in China is not THE reason people report so many ST tire failures. This website is a good read and the author has spent a lot of time in the tire industry. RV Tire Safety
On a bit of a related note, I asked a local dealer why you would want to go with the GY Marathon tire upgrade option they have on a certain brand over the Freestar load range C tires that come with the TT, and they had no answer. Apparently they don't get many asking to spend extra $$ on upgraded tires. I wonder how often this happens out there and owners really do end up with inferior quality tires and they could have upgraded to better tires at the start for little extra cost and perhaps have avoided a blowout?
Not looking to start a heated debate, especially since today is Remembrance Day... (no WWW III please) Just wondering and just looking for some easy-going thoughts.
