ZeeLet50
Jul 08, 2013Explorer
our latest camping trip to PA
Just spent the Holiday weekend in Sinnamahoning State Park. Great wildlife weekend as we saw bald eagles,Elk many nursing deer and a 2yr old bear cub.
Anyhow few troubles with the camper. One was the hot water heater throws a fault when I try to use propane to heat. It will ignite if I open service door but will not otherwise. Its like its starved for air.We used campground showers so all hot water needed was for washing dishes. Second problem was upon arrival home this evening ,when I unhitched, found metal shavings and the ball was all worn at the top.It was not like this when docking at the camp site. I do lube every other trip but apparently it was too dry. Will replacing the ball be sufficient? TT is still under warranty so may have dealer check out heater.
