Indoor/ outdoor carpet is disgusting when wet hard to dry and almost impossible to clean… and that is the pros for it…
The cons are it will kill the grass in just a few days making the area muddy or dusty for the others that follow…
It should be forbidden to use on any area that has grass and is the cause for rules against the use of anything in many places already…
If you want or need ground cover the woven plastic mats allow air, sunlight, and water to pass threw to at least minimize permanent damage to grass…
They also don’t hold dirt, dry quickly, and are easily cleaned…
