Looking to add a removable outdoor sink, but haven't found one we can easily attach and remove. I was thinking one we can connect to outside shower hose, since it already has hot/cold. Can't see a ...
If you make a "cutting board" to insert into this Utility tub, you have everything you need. The legs slide into molded holders in the bottom of the sink. The only issue would be if you have adequate storage space.
A smaller alternative would be a tub that mounted onto either a stand or the side of the trailer. A bar sink is also small and would add some class to the project.
