Artum_Snowbird
May 26, 2017Explorer
It might be as simple as tightening the neutral wires on the feed panel. You can check easily with a meter to see if it is the hot feed to the devices, or if it is the neutral return that has failed.
On volts, have one person hold one lead on the neutral bus, or use a jumper, and put the other end into the bottom of a socket. If you now show power, it's the neutral return that is off.
