- austinjennaExplorerCant you just open the slide when you pull over for a lunch break and get into the fridge?
- jeepermanExplorerI had a feeling they were 120 v
Only. On the rear kitchen model the slide
Covers the fridge when in. So back to the
Yeti cooler to keep lunch cold when on the road. - KD4UPLExplorer III've never seen one that wasn't just a cheap "dorm" 120 volt AC refrigerator. Not only are they AC only but those things are very energy inefficient. If you want to run it with an inverter from a battery you can but be prepared for it to use a lot of power.
- DevocamperExplorerAll the ones we have seen are 110vac . Unless you have an inverter to power it while traveling it doesn’t seem to useful unless you pack it , cool it down and are not. Traveling to far
