WyoTraveler
Mar 17, 2016Explorer
DutchmenSport wrote:
You will need to unscrew the entire plate so you can get to the back of the connector. There is a coax cable screwed into the other side of that little plug and the only way to get to it is to remove the plate so you can unscrew it. Then remove the plug and insert a new one, and reattach the coax inside the wall, and screw the plate back on. (Putty it of course).
Yes, and I would buy a new one with a cover to keep dirt and moisture out.
