atreis wrote:
lots2seeinmyrv wrote:
First time living in snow country...for those of you who store your RV outside:
1) Do you keep your trailer plugged into the house and put a small space heater inside and set it at 40 degrees?
2) Keeping the battery charged...if I keep the trailer plugged into the house it will stay charged. OR is it best to pull out the battery and put it in the basement so it does not freeze.
Would like to know your procedure.
Thank you.
1) No!! What a horrible waste of electric that would be (even at 40 degrees).
You do have to winterize the plumbing so that it isn't damaged from freezing water.
2) Assuming you're using a stock converter, leaving it plugged in could be bad for your batteries. I leave mine unplugged and let the solar panel keep the batteries charged, but without the solar panel, I would make sure the batteries are fully charged, disconnect them completely, reconnect them every couple months for a few hours to charge back up. Fully charged batteries won't freeze in MD. (Dead batteries could.)
I guess you didn't bother to read ALL the posts..
The OP does indeed have a modern THREE STAGE converter.
It WILL NOT HARM, DAMAGE, BOIL, MUTILATE, FOLD, SPINDLE the batteries if left on 24/7/365..
You would have to go way back to perhaps late 1990s and earlier to find an old school single stage which would have a great chance at boiling the batteries dry..
The only issue I see is leaving the converter on and batteries connected 2/7/365 is you DO need to "monitor" the battery electrolyte levels periodically. This can be an issue with "sealed" no maintenance FLA batteries. In the case of sealed batteries FLA batteries the water over time will be lost and you can not add any in when that happens..
But for the most part 2 or 3 stage converters drop the voltage well below the boiling point once battery has been fully charged. This drastically reduces lost water (note, I did not say it stops water lose, just reduces the amount of loss).
