BenK
Oct 12, 2020Explorer
Over loaded pickup
Wonder how often this occurs...think often https://fordauthority.com/2020/10/not-smart-ford-f-150-owner-exceeds-their-trucks-payload-capacity-by-a-touch/amp/
Cummins12V98 wrote:JRscooby wrote:
Overloaded? Likely, but a little for-thought in the order of loading could improve things a lot. Put that sheetrock on the floor of bed would lower COG a bunch. Then put lumber on top, long boards end even with tailgate. Then center the shorter boards over front of bed. This would move COG back up, but also forward to level truck out
COMPLETELY disagree. The load is as far forward as possible of all items. Nothing is going to change the front to back load. Lowering the drywall "may" make it less top heavy.
That is insanely overloaded and completely unsafe. I bet the steering is VERY loose as the front tires have been unloaded most likely.
But hey some "E" tires and bags = "Good To Go".
