BenK
Oct 12, 2020Explorer
Over loaded pickup
Wonder how often this occurs...think often https://fordauthority.com/2020/10/not-smart-ford-f-150-owner-exceeds-their-trucks-payload-capacity-by-a-touch/amp/
JRscooby wrote:pitch wrote:
Our local gravel pit will not load a single wheel pick up,no matter the rating.
Show up with a single wheel 3500 and you will be shovel loading right next the 1500,s
Around here most of the quarries will not load any pickup bed.
The loader operators are in a hurry to get trucks loaded. To see the pickup you need the bucket pretty high, and gravel falling that far can do some damage. (I had to sign a release before they would load the 10 ft bed on my F-5.)rhagfo wrote:JRscooby wrote:
Overloaded? Likely, but a little for-thought in the order of loading could improve things a lot. Put that sheetrock on the floor of bed would lower COG a bunch. Then put lumber on top, long boards end even with tailgate. Then center the shorter boards over front of bed. This would move COG back up, but also forward to level truck out
:S
That would likely not change a thing!
BULLSNOT! The way it is loaded now, most of the weight of the boards is hanging in back of the rear axle. If it was loaded with them on top of the stack, and hanging over the cab, part of that weight would be carried on the front axle instead of levering weight off that axle and adding to rear.
