Grit_dog
Mar 15, 2016Trailblazer
JIMNLIN wrote:
Some points here on your upgrades.
Although you have 3800 lb rated tires did you also upgrade the lower rated OEM wheels ?? This is one area 19.5" wheels and tires shines for carrying heavy truck campers.
Air bags with high inflation pressure can add to your trucks sway issues. The truck suspension shop has the right idea about heavier rear spring sets.
And your trucks axles load numbers don't add up. Scale weights gives us a number in 20 lb increments. Your 5000 lb front and 6800 rear axle numbers must be a estimate..... which add up to 11800 ....not 12100 lbs.
I would want to see my trucks actual scaled separate front and rear axle load numbers. That way you know which components may be severally overloaded and the best fix.
Lol, really? Yeah the numbers don't match by 2.5%. Oh the humanity......
44,068 PostsLatest Activity: Jun 10, 2026
