Anonymous
Aug 24, 2016With what you're planning on running I doubt that you would even kill the trailer's battery, let alone the truck's battery as well. That is if you're starting the night with a full battery.
I have yet to kill the battery on the truck overnighting in a parking lot. As long as you aren't running a ton of stuff then you should be ok. I have a constant hot line and leave the 7 pin in all night. If I did actually run the truck's battery down then I could use the genny to get going. I've never had to do that though.
