Old-Biscuit
Dec 29, 2015Explorer III
donn0128 wrote:
Why do you need access To the back? Hot rod is installed in the drain hole.
So that OP can get to the tank wall and install the t-stat that comes with the Hott Rod Kit.......cut a section of styrofoam insulation away to expose tank. Can't do that from outside compartment.
Plus need to run AC wiring from outside to inside.
Access to backside of WH makes the install doable
