Idaho_Joe
11 years agoExplorer
Paint recommendation
Looking for some advice on paint my rig. 1971 Aladdin Car-Pet with aluminum siding. What type of paint should I use when I repaint it and do I need primer. Photos are under my post 1971 Aladdin
retiredcamper2011 wrote:
Joe, My son works in an auto body shop and has general knowledge of paint issues, but is not an expert. Here is what he said:
You will need to either first apply a "direct to metal" sealer or primer. Something that chemically etches to the aluminum. After this, you can paint it with any automotive paint you want. If you are going to do any "body work" first, you will need to use primer and then sand it before painting. If no body work, sealer or primer is fine and no sanding required. In either case, you must do the sealer or primer before painting. Hope this helps. If you know someone who paints cars, their advice would be invaluable.
