93Cobra2771
Feb 19, 2016Explorer
Would it work? I think with proper surface prep, it would work. But not as thinned paint. It would need to be the real stuff. Instead of clearcoating, they make a UV top coat that is keeps the bedliner material from greying out. It's supposed to be flexible enough to handle a beating in the bed of a truck.
I would contact the RV armor people and see what they say. I'd be willing to bet they have done something similar.
I think you will find it's going to be VERY expensive to do. Might be a bit less expensive if you do the surface prep. And you can have it sprayed with the smooth texture material instead of the textured.
If it were done in sections (for example, flat sides first, then nose, then roof) with plenty of overlap to allow for cracking at the joints, it might work pretty decent.
