Intravino, thanks for the additional link. I still get the same "Error code 16 - This request was blocked by the security rules". There is nothing wrong with the link, but I am not in America and sometimes traffic to Europe is blocked due to GDPR laws.
But. When Kayteg says the front jacks are crooked and the camper has additional support... I think I'd pass on the offer. A good repair would end up with everything straight and solid, as good as new or better (better because more work and diligence went into the repair than the factory could afford). With the very limited information available to me, there would be too many red flags on this offer.
Should you still pursue this camper any further: Why did the damage happen? There is a world of a difference between a solid camper that nicks its front right jack on a low wall or that is involved in a traffic accident, and one with structural damage (e. g. from rot) where the jack just gives way. In the first case, you can expect limited damage. But you can also expect damage to extend to other parts of the camper. For instance, seams that came unsettled and would start to leak.
Was the camper rolled on its side or crashed on a cabover corner? If you just tear off a jack, it sometimes just tears off without much additional damage (seen it once). If the camper is on the side or on the cabover, a lot more can be damaged, depending on the cause and the energy involved as well as the care involved in righting the camper. Damage may be found in spots all over.
Why was it declared "totalled"? What was the extend of the damage? Were parts of the framing replaced? Which ones?
I believe those Mavericks were wood framed? 8 years is not that old, but it is plenty of time to cause serious structural damage if a major leak goes unattended and the camper is stored outside.
I have an unpleasant feeling that a number of decent campers will be on the market later this year for reasons having to do with the current economic "situation". Be patient...
