mkirsch
Apr 11, 2022Nomad II
Palomino is famous for changing model numbers but cranking out virtually the same camper. An M-800 is now called a Backpack HS-750. Main difference being a N-S bed vs. an E-W and a couple hundred pounds on dry weight.
COG is 27" on the HS-750.
The HS-750 is advertised, "1/2 Ton Truck w/ 5’6” up to 8’ Bed."
So, much ado about nothing. You will be fine.
